    TIPS:
Meziere Electric Water Pump, low hours
NotEnoughGPs
Meziere Electric Water Pump, $275 or best offer.
This pump is like new. I mean like new. I don't have the exact number of hours that this pump has run, but I believe somewhere between 100 to 300 hours. Meziere says these pumps have a 2400+ hour life expectancy. That translates to around 100,000 miles.
There is nothing wrong with the operation of this pump. There is some paint worn off the top side as you can see in the photo. I do not have the gasket for it. The same gasket used for the stock pump will work.
This Meziere electric water pump is for the GM 3800 engine Series II & III. A "875" serpentine belt is suggested for use with this pump.
Under normal use, the pump will draw 6 to 7 amps.
Color is burgundy.
Complete unit weighs 5 lbs.
If you want more photos, I have them.
IF you need more info about this pump, you can text me at 724-859-6489.
Shipping is extra.
Payment only by Paypal.
