methinjection
riceburner
i am going to be picking up a system for my car next month and had some ?'s. i tried searching but could not find any answers. first would be, would it be plausible to tap the phelonic spacer for the nosle? second is, what all is involved with tuning the system(map veriable spray). and what kinda mix should be run for a stock to 3.4 pulley?
TDCRacing can get you a spacer already machined for the nozzle relatively cheap. As for tuning, it depends on the system. With the Devil's Own, it has a controller with two knobs; what PSI the injection starts, and what injection the injection maxes out. With putting the injection in front of the supercharger, I think that a 50/50 mix is good.
make a spacer and inject after the blower AND before the blower. a small nozzle in the throttle body spacer with two slightly bigger ones in the spacer between the lower intake and the blower.
that is what i would do if i were to do it again.
even distribution and better spray pattern. the smaller nozzle you can use the more atomized the methanol becomes when you spray it. i only ran one nozzle in my blower case, but if i were to do it again i would make a spacer to go above the lower intake.
