mburke
mburke
Hi, I just signed up today and already have a problem that you can maybe help me with, I have a 2002 pontiac grand prix that has been sitting in my yard for a year. My son used to drive it but has since left the nest. I started it up today and was going to move it and the brake pedal went to the floor, I went under the car and found a leak in the passenger front metal line, I tried to follow the line and it looks like it went into an aluminum tube and could not find it again but I know it ends up in the valve body (don't know the real name) next to the master cyl. 2 lines come out of the master cyl. and go into the valve body and out of that four lines come out, one to each wheel, my question is there is a color circle next to each line, each line is a different color. Which color goes to the passenger front? I want to unbolt the line and replace with a bolt of the same thread and then I could drive it to a shop a few blocks away and have the line replaced. thanks, Mike
It heads up over the exhaust and then down under the booster, over to teh abs module. Look close on the driverside with a flashlight and you should be able to find it again.
