mazdaspeed 3 wheels will they fit
justin10morrissey
heres the specifics its a 2010 mazdaspeed 3 set
Style: 5 "Y" Spokes
Lugs: 5
Bolt Pattern: 114mm
Offset: 52.5mm
Tire size: 225/ 40/18
i know the tires are a little small but im planning on buying a mazdaspeed6/3 so if they will fit my grand prix i can justify the purchase before i get one
Wheel bolt pattern
Our cars stock have a 5x115 bolt pattern. Now that's all fine and dandy, but wheels with a bolt pattern of 5x114.3 also fit. If they wobble or vibrate a lot you may need to run hubcentric rings, but that is all you would need in order to run them. Some people say that the slightly smaller bolt pattern puts stress on the studs and will snap them when driving aggressively. There are a ton of people who have been running that bolt pattern for years who would argue hardly against that point. This means that as well as some GM fitments, you can also look for mustang, eclipse, maxima, etc. wheels because they have the same bolt pattern. The thing that matters is the hub bore. So long as the hub bore is the right size then you're good.
