indygrandprix
Got a trouble code for cylinder 3 misfire a few days ago. Swapped the coil pack out with one from my 01 GP but still had the same issue and now it has gone from just cylinder 3 misfire to a random multiple cylinder misfire. Thought maybe it was the MAF as the car stumbles under semi hard to hard acceleration and has a hard time keeping speed and sorta bogs on the highway. Tested the MAF and it has voltage but the Hz readings are off compared to what my research indicated they should be.
I got 2.7 @ 750RPM(Idle), 3.4@ 1500RPM and 4.1@ 2500 RPM
My research indicated I should have 3.2 @680 RPM(Idle), 4.2@1500RPM, and 5.2@2500 RPM
From what I read it's more important that the readings increase smoothly than what they are but I'm not sure if thats true. So is my MAF sensor bad? I did clean it which made the readings a tiny bit higher. The readings I posted here are what I got after the cleaning.
Also at ~3500 rpm I got about 4.9Hz but I couldn't find a spec for that RPM
If it's not the MAF what would the next thing to look at be. Ignition Module? I have no other codes.
