MAF brand?
shedawg
OK, tried to take cheap route and used aftermarket reman MAF....should have known better - and if I would have known about this forum earlier, would have. Question now is do the AC Delco MAF's play welll with us? (01 GTP) I think the OEM one was AC Delco branded but not sure. Dealer wants $391, GM Parts direct is $256 with shipping and Rock Auto has AC Delco for about $175 with shipping. Anyone know if it's compatible and makes PCM smile?
If you have access to a junk yard see if you can grab one. Should be a bunch cheaper, but I would see if they warranty any parts just incase it doesn't solve your problem or is DOA.
Sent from the Milky Way
Yeah, possibility, but I live pretty much out in the sticks with none to be found in 60 mile radius at least. Don,t even mind paying the $171 if it would work.. .still a lot cheaper than $391. Just hoping someone could verify if AC Delco is compatible with the PCM on these cars. Thanks for the reply.
acdelco is what your car came with. aka oem. thats why used junk yard maf's rule. im running on a used maf for the last 4 years.
