M90 Kit vs. Top Swap?
Traeger2591
What is the difference between these two mods? I had seen several people talking about the m90 and wondered what it was so I went and looked on zzp and it looks like the m90 is basically the same thing as top swapping an L36. I saw all the other parts that it said were required to install it so it really isn't much cheaper is it? Can someone help me out here?
top swap- swapping all the parts including harmonic balancer from an L67 besides the bottom end.
zzp's m90 kit- only requires to use their modded LIM and bolting a s/c to it. I think it requires to use their fuel rails too (not sure though). This kit only runs one belt.
Take you pick. One belt seems kinda silly to me...
one belt for the lose. you can do a half and half swap if you dont want to switch over your heads, but a top swap will be cheaper.
im running the m90 kit with the gtp pulley system. if i could do it all over again i woulda bought a L32 from ed with everything on it and swapped that in
