M-90 stock cam record???!!!
Well the Chicago Garage had a little track outing at byron,il.
We had been working on Mike Steinman car(12.99someday,11secsomeday) since the last TCG outing to make sure it was going to break 11s. Sure enough on its 3rd pass it did ...and a backpass to match.
[email protected]
1.765 60'
With no rear end suspension limiters on 100k stock rear struts and lowering springs.
While it will be argued to death because of the nitrous use but this did set the m-90 stock cam record which was held by Steve mayes for the last 4 years or so.
Weight reduction was done, about 150lbs removed and nothing that couldnt be put back on in minutes.
For the next pass we put on the cable mod, tho it didnt help but did back up the record. Each pass were about a tenth slower the the other because of heat and plug issues.
11.9s@114
12.09@111
The Car needs more fuel/alky tuning seeing as the AFR was in the very low 10s all day excpet for the 11.8 pass which was in the 10.90s to 11.30s. Which was not making for easy takeoffs as the car would get real rich and fall on its face a little after the launch unless spraying out of the hole which would break loose the tires with ease.
The track kept having little 5 minute raining sessions and from what we were seeing the track prep was starting to fade a bit so times were left at that
we packed up and Mike drove it home.
This is probably the last time the car will see the track this year so we were glad to see it counted.
With a few upgrades this winter the Non-IC record is the next goal it would seem...or at least somthing to shoot for.
Congrats to Mike again
those are some good times. awesome.
im going to be going e85 and meth, non-IC and see where it gets me. ive got a set of heads that i could put on too, just want a reason to. if i run 12s as is, ill probably just sell them.
12.08 and no he wasn't spraying, but i shall be the record holder until someone beats me and i don't care how they do it as long as it's an m90.
i dont want to spray my car. otherwise i could see with some slicks and spray that i could get somewhere in your region. are you planning on doing everything BUT a cam as in heads and everything?
It's pretty much pointless to run heads on a rocker setup so those will stay stock. I'm going to switch to a Gen V setup with a n* tb and a better intake. I'm upgrading the fuel system to run a wet shot instead of a dry shot. wet shots have way more potential for making power imo. I couldn't get enough fuel through my injectors so a wet shot is needed at this point. I don't believe anyone has every ran a 125 dry shot on a gtp before, so i think that was a first. Nor ran 11's on a stock m90 either. My point was to go a different route, and that i did lol. Now to really make the power i have to go more mainstream. Next goal... 11.49 or faster. The only way that's gonna happen is to let the Sinisterdd.com crew think up some crazy stuff like they always do. I got 11.8's because of them, and they'll get me 11.49 or faster too. :th_thumbsup-wink:
an intercooler is your next best bet as far as any modding goes on top of that wet shot.
if you come up with some direct injection youll be well on your way then.
that's in the works....
As for an i/c i wont' be getting one. I'm going to get as low into 12's as i can without one (off juice) I don't have the money for an i/c or anything of the sort.
Congrats Mike! That is awesome to see those numbers with what was put into your car! Looks like it is time to upgrade the trans a little more before next year's outtings :th_king-evil:
dave... seriously... I wouldn't have even tried if you didn't build my trans. I owe you my 11sec slip because without that trans you built me it wouldn't have happened. Bob said it might need an upgrade or two for next season. Do you think i can pull off some 11.50 passes on it before i get it freshened up? It's only got 3,532 miles exactly on it right now and it's still shifting like a champ. Tanny man FTMFW!!!!
