ls6 springs
coreysGTP
i was wondering while running the ls6 springs can i use my stock dampers the cam is a xp or do i gotta do some more mods to my head to run the ls6 springs also ?
LS6 springs can be run with stock retainers. However, running a XP cam requires upgraded retainers and valve seals to handle the amount of lift the XP creates.
Never ran an XP so I can't give an opinion. Try searching on the forum. Should be lots of posts regarding the XP cam. As far as the retainers and seals, I shop at Intense and ZZP. BTW, if you are looking to install a L67 into a '94 GP, look up a member here by the name of RALM. He's working on a '95 and might be able to help :)
thank u heres the deal with my built tho im useing a l36 bottom end i blew my rod in my l67 so im top swaping into a rebuilt piston etc a new xp cam l36 and my heads have 154k on em so another question is im on zzp right now and are there valves good to use ? i heard good and bad about zzp like the front log
well im running 3.4 pulley but im thinking to return it to zzp for a 3.25 pulley i have headers ls6 springs xp cam going slap a gen v p&p this tax return and a heat exchanger only head work is springs and im buying a set of lucas 42.5 injectors soon after i pay off the 94 gtp im moreless trying to running a 13 this summer but another problem or maybe its not a problem is the l36 bottom compression is different then the l67 so rlly i guess my question is will the pulley and l36 has issues in the long run or will i be fine ? im still learning on the 3800 motors i use to be all about 4g63
i still havent found a tuner yet i mean i have dropped it in yet so i was putting that off my tuner moved to fl so im like dang i wish i woul dof learned to tune while i still had my tsi awd lol would of been a plus for me
