    TIPS:
LS6 Intake Manifold, Fuel Rails/injectors & inj. adapters
fisher580
i have an ls6 intake manifold, cleaned and painted, with the ls6 MAP sensor plugged, fuel rails and injectors are included. I also have the fuel injector adaptors so the ls6's work with the ls4 harness.
all that is needed to swap would be a throttle body adapter, gaskets, and a few hose fittings. along with sanding the bottom to match your valley cover. and mounting your map sensor on the back.
$600 shipped to 48 states.
will consider offers
located the Dubuque, IA. willing to go lower with a local pick-up
text 56three-451-51O8 for pictures
Thank you for looking
