LS6 intake + LS2 TB, will they work?
gagt3100
As the title states will it? also is the LS2 TB worth getting over the stock LS4? will I need an adapter for them to work together?
-Thanks'
Awesome thanks!
Edit: I think 400 for LS6 intake and LS1 fuel rails, 55 for the adapter and 150 for the TB aint that bad.
Be patient on the ls6 intake you can also find ls2's dirt cheap as well but those need some porting to Hang with the ls6 . keep in mind you can always use your ls4 throttle body which matches the ls1/6 diameter and all you'd need is a custom throttle body adapter. Which would be a more cost effective solution depending on your resources. I chose the ls2 tb because I knew eventually I'd want more headroom for future mods
