LS1 brake conversion complete
4birdman
My brother and I did a bunch of work to his 2000 GTP last night.
I made a bracket and swapped C6 brakes onto my 98 TA, so I took the old calipers and drilled out the bracket holes and retapped them for the GP bolts. Then we blasted the calipers and powdercoated them. Bolted right on, no problem. :D
The rotor part number is the same for the 00-05 imp's as the 98-02 F bodies.
The hub bore is the same, but the lug holes are enlarged to fit both bolt patterns.
