Wakingcrow
OK here's the sitch:
Fans don't turn on until like 240F or whatever and I read that's by design, but in my opinion that temp is way too high, especially in a car that the AC doesn't work (different story: replaced condenser and compressor from junk yard and still has slow leak that I can't find, whatever.) So I have to jumper the fan relay whenever I drive more than 15 minutes, because it's summer. Then I have to pull the jumper every time I park because the fans kill the battery rapidly. It's a lot of hood opening and close to needing to replace the hood strut at this point. See the chain reaction?
So here's the question:
Is there an aftermarket temp sensor that will close the relay at a much lower temp? Or another known workaround.
Thanks.
Thanks.
