low light on need help
1fastam
98 gtp gauge cluster in center of dash only has low flashing. no other features. normally displays boost and miles per gallon .anyone kno what this light means? thanks for the help!
Gauge cluster in center of dash = Drivers Information Center.
If all it says is "low", you should be checking all your fluids and pressures, then replace the dic because it probably has some lights burnt out.
on the 98 gtp the low fuel light is displayed in gauge cluster in dash at steering wheel.
could it be the oil in
the supercharger is low?
im tellin you its the distance you can travel because your car has calculated how many gallons you have, your mpg, and how far you can go.. after it gets to a certain number it just flashes low..
As I recall there's a corresponding light next to words that goes with it. If you cycle through you should be able to figure it out as long as it's only one bulb that is out.
Low oil life
Low fuel in tank
Low tire pressure
Are the only two I think would be on there
it turns out that when he changed the oil he didnt mash the pedal as required and evidently it set off this light.
went through the info. center and cleared it now its fine ,jimmy thanks again for all the help.much appreciated!
