I have a 2004 gp gt. The car sat in my garage for a week as I did some touch up body work to it, getting rid of some rust spots before the snow starts and when I finally drove it again I had no power locks or windows. A mechanic told me it was the master window switch so i rplaced that and it did nothing. When I hit the drivers side window switch after the key has been pulled from the ignition the switch makes a buzzing noise. When I use the unlock switch the BCM will make a clicking noise. My key fob does not unlock or lock the doors but it still opens the trunk and when i hit the unlock on the fob the really in the fuse box under the dash will click but nothing happens. Along with all that the rear window defroster quit working and every now and then my left tail light will quit working, sometimes it doesnt work at first then starts working or the other way around. Ive checked any grounds I can find and fuses but not luck. Also when i hit the unlock button on door it sounds like the locks are trying to move but just not enough power going to them.
Any thoughts would be great. Thanks
