hey everyone,
first post I here but I have a 2004 grand prix gtp I've changed the water pump, thermostat cooling elbows throttle body gasket( the one with coolant going through it) and the person who owned it before me said he put in a cosmetic head gasket. just recently I was very hot (temps would peak at 240 with a 180 degree thermostat) and I seen my green coolant that I put in last year (flushed out dex) has turned brown and dirty so I used a chemical flush and kept it in there for two days over 100 miles then flushed that out with plenty of distilled water went through 15-20 gallons. after doing so I replaced the radiator (thicker core from Buick regal gs but basically new only 5k miles) new cap new reservoir bottle and both cooling hoses (to silicone hoses) and now im leaking the whole coolant bottle (from fill line at half way) in less than 100 miles (long trips) and I've looked and don't see any puddles near the intake and valve cover. also no coolant in oil. btw car runs phenomenal until coolant gets low then it starts to run hot but doesn't overheat only reaches about 230. never had a low coolant light just keep noticing the coolant bottle is empty help need this thing to get me to school for winter (60 miles one way) didn't leak before when it was overheating at 240 temps coolant was just brown and nasty which is weird since I changed all the coolant with green stuff about a year ago and it stayed green throughout winter
