Long crank in the mornings....
rizer
Recently I've notice on cold mornings, after letting the fuel pump prime, it will crank long then start to want to start over but acts like I'd need to pump the pedal as If I had a carb. If I turn if it off then crank again, starts normal. Also noticed my freeway mpg have dropped to bout 20 mpg (don't know if it matters).
It's a 04 gtp w/ new plugs and wires.
Any idea on where I should start?
Okay, I'll try that, thank you. I forgot what brand but they were the ones from the factory, made sure of that.
