List of Torque specs
Andrew_99GTP
I haven't seen one of these yet around here. I was thinking someone could get a list of torque specs for fastners on our cars. I am about to go through the top end of my regal and replace all the gaskets but I can't seem to remember the torque specs. I hope this was the right section for this.
Fastener Tightening Specifications
Application
Metric
English
Accelerator Control Cable Bracket Bolt
16 N-m
12 lb ft
Air Injection Check Valve Pipe to Exhaust Manifold
10 N-m
89 lb in
Air Injection Check Valve to Bracket Bolt
25 N-m
18 lb ft
Balance Shaft Driven Gear Bolt
22 + 70° N-m
16 + 70° lb ft
Balance Shaft Retainer Bolt
30 N-m
22 lb ft
Camshaft Position Sensor Bolt
10 N-m
89 lb in
Camshaft Sprocket Bolt
100 + 90° N-m
70 + 90° lb ft
Camshaft Thrust Plate Bolt
15 N-m
11 lb ft
Canister Purge Solenoid Valve Bracket Bolt
50 N-m
37 lb ft
Canister Purge Vacuum Switch Bolt
50 N-m
37 lb ft
Connecting Rod Cap Bolt
27 + 50° N-m
20 + 50° lb ft
Crankshaft Balancer Bolt
150 + 76° N-m
111 + 76° lb ft
Crankshaft Main Bearing Cap Bolt
40 + 110° N-m
30 + 110° lb ft
Crankshaft Main Bearing Cap Bolt (Side)
15 + 45° N-m
11 + 45° lb ft
Crankshaft Position Sensor Stud
30 N-m
22 lb ft
Crankshaft Rear Oil Seal Housing Bolt
15 + 50° N-m
11 + 50° lb ft
Cylinder Head Bolt
50 + 120° N-m
37 + 120° lb ft
Drive Belt Tensioner Bracket Bolt/Nut
50 N-m
37 lb ft
Drive Belt Tensioner Bracket Stud
6 N-m
53 lb in
EGR Valve Adapter Bolt/Stud
50 N-m
37 lb ft
EGR Valve Inlet Pipe Bolt
29 N-m
21 lb ft
EGR Valve Nut
30 N-m
22 lb ft
EGR Valve Outlet Pipe Bolt/Nut
29 N-m
21 lb ft
Engine Block Coolant Drain Plug
30 N-m
22 lb ft
Engine Block Oil Gallery Plug
30 N-m
22 lb ft
Engine Coolant Temp Sensor
23 N-m
16 lb ft
Engine Flywheel Bolt
15 + 50° N-m
11 + 50° lb ft
Engine Front Cover Bolt Stud
20 + 40° N-m
15 + 40° lb ft
Engine Lift Bracket Bolt/Nut./Stud
30 N-m
22 lb ft
Engine Mount Nut Lower
78 N-m
58 lb ft
Engine Mount Nut Upper
78 N-m
58 lb ft
Engine Oil Pressure Indicator Switch
16 N-m
12 lb ft
Engine Wiring Harness Heat Shield Nut/Bolt
10 N-m
89 lb in
Exhaust Crossover Heat Shield Nut
20 N-m
15 lb ft
Exhaust Crossover Pipe Bolt/Stud
18 N-m
13 lb ft
Exhaust Manifold Bolt/Nut
30 N-m
22 lb ft
Exhaust Manifold Stud (Inner)
30 N-m
22 lb ft
Exhaust Manifold Stud (Outer)
10 N-m
89 lb in
Fuel Injector Rail Nut
10 N-m
89 lb in
Fuel Injector Rail Stud
25 N-m
18 lb in
Fuel Injector Sight Shield Bracket Nut
30 N-m
22 lb ft
Generator Brace Bracket Bolt
50 N-m
37 lb ft
Heated Oxygen Sensor
42 N-m
31 lb ft
ICM Nut
50 N-m
37 lb ft
ICM Stud
6 N-m
53 lb in
ICM Wiring Harness Bolt
2 N-m
18 lb in
Idler Pulley Bolt
50 N-m
37 lb ft
Idler Pulley Bracket Bolt
30 N-m
22 lb ft
Lower Intake Manifold Bolt
15 N-m
11 lb ft
Oil Cooler Adapter Connector
50 N-m
37 lb ft
Oil Filter
30 N-m
22 lb ft
Oil Filter Adapter Bolt
15 + 50° N-m
11 + 50° lb ft
Oil Level Indicator Switch
20 N-m
15 lb ft
Oil Level Indicator Tube Nut
19 N-m
14 lb ft
Oil Pan Bolt
14 N-m
125 lb in
Oil Pan Drain Plug
30 N-m
22 lb ft
Oil Pump Cover Screw
11 N-m
98 lb in
Oil Pump Screen Bolt
15 N-m
11 lb ft
Power Brake Booster Heat Shield Nut
20 N-m
15 lb ft
Spark Plug
27 N-m
20 lb ft
Starter Motor Heat Shield Bolt
30 N-m
22 lb ft
Throttle Body Nut
10 N-m
89 lb in
Throttle Body Support Bolt
10 N-m
89 lb in
Throttle Body Support Stud
6 N-m
53 lb in
Timing Chain Dampener Bolt
22 N-m
16 lb ft
Upper Intake Manifold Bolt/Stud
10 N-m
89 lb in
Vacuum Solenoid Valve bolt (with NC1 California Emissions)
10 N-m
89 lb in
Valve Lifter Guide Retainer Bolt
30 N-m
22 lb ft
Valve Rocker Arm Bolt
15 + 90° N-m
11 + 90° lb ft
Valve Rocker Arm Cover Bolt
10 N-m
89 lb in
Water Outlet Bolt
27 N-m
20 lb ft
Water Pump Bolt
15 + 80° N-m
11 + 80° lb ft
Water Pump Pulley Bolt
13 N-m
116 lb in
Wiring Harness Shield Bolt/Nut
10 N-m
89 lb in
I need the specs for the valve body and pump bolts. Also those for the bolts holding the cover over the drive chains. Can anyone please help?
Thanks. Dan
91239887
What year does this apply to
I need them for a 2005 GTP
Doing a head gasket
These numbers will work for both Series 2 and 3 engines. The design of the supercharger/upper intake was the only major difference, and bolting everything down will be to the same spec. (source: just like many here, I've ran a 2006 GTP engine 11yrs for my turbo setup and 2006 LaCrosse engine 13yrs for my supercharged setup, both with combinations of Series 2 and 3 parts all over)
Thank you
Question- the metal plate that is attached to the trans and engine (passenger side)
I cant seem to figure out how it goes on, can I go with out it
It should connect to the differential cover and the block behind the oil pressure sender. I'd put it on there for the support.
Thanks
I put it all back together without the support bracket and it feels bumpy, it feels like the motor mount is bad
For this 2005 do I have to take parts off to fit it back on?
You may have to move the PS pump for access, along with the splash guard in the wheel well.
Also, check all your mounts to make sure they're snug.
It's not a big task... Pull wheel, 3-4 plastic retainers for splash guard, 2x13mm bolts thru PS pulley... Install 4x bracket bolts (loose at first to line them up, then snug down).
I tried to line it up for like 40 minutes before I put it back together
With no luck, I will try again this weekend
But now I have another problem, after driving the car for more than 10 minutes if I come to a stop sign the rpms stay high
Like the throttle body is sticking, I can hear the car revs high
What could be causing that
