'04 with 227k on it, recently replaced the LIM gasket about 10k ago. I've got an oil leak in between the LIM and the valve cover (both sides). When I installed the LIM I torqued to specs and then went back over and snugged/double checked each bolt with a 1/16-1/8 turn just to be sure as the torque specs are pretty low. I let sit overnight to let the RTV dry. Double checked the bolts again.
I had replaced the valve cover gaskets about 20-30k ago, then realized I needed to also replace the grommets which I did about 5k after that.
I'm not sure if it is at all possible that I over torqued the LIM at all or if so that would cause an oil leak in between the LIM/valve cover as I thought a hallmark of a LIM is leaking coolant and not oil.
I'm highly suspect of a valve cover gasket (VGC) but since I recently replaced the LIM I'm nervous that this might be the issue, but haven't come across a LIM which would result in leaking oil at the location I'm seeing it at.
I'm going to replace the VGC just because, well that's the easier thing to do, but wanted to see if anyone's had an experience to mine or could speak to the oil leak I'm having.
