GTP2G
Im getting ready to do the lim gasket and replace the lifters on my 00 gtp. just got a few questions before i start. been doing alot of reading on this forum and have learned ALOT of info about this job. anyway my questions are, im wondering if i should get the garlock sc gasket or just the felpro. read some stories about garlock or (garleak) leaking. also im replacing the lifters while im in there and ive also read that the comp cams lifters have some type of defect?? if the comp cams lifters are no good what would be a good alternative for a stock replacement. any insight would be great. also here is a list of parts i will be replacing. please feel free to add any suggestions. thanks.
lim gasket (alumminum)
lim o rings
valve cover gaskets
coolant elbows
throttle body gasket
sc coupler/sc oil
sc gasket garlock or ??
lifters
rocker arm bolts
180 thermostat, and gasket
lower rad. hose
fuel injector o rings
lim o rings
valve cover gaskets
coolant elbows
sc coupler/sc oil
lifters
rocker arm bolts
lower rad. hose
