Lifter replacement
kfish
Hey all, first time posting here. I got a 98 Grand Prix Gt. I got it about 2 weeks ago, got it cheap because it was ticking. I determined it was a lifter, so for the last 2 days ive been working on and off on the engine. I replaced all 12 lifters cleaned all pushrods replaced all gaskets etc. Did everything by the book. Now that Im nearing the time to start the engine is there anything i should do? Maybe disconnect the ignition module and crank the engine for a few seconds to prime everything?
Did u wash down the lifter valley with motor oil, then change the oil?
I disconected the ignition harness and cranked mine over a few times, then the battery went dead :p
I ended up starting the car with jumper cables, first start
ya i poured about a half quart thru the lifter valley, should i change oil before 1st start?
