beastin1
Heres the problem and it's only noticeble at slow speeds when in parking lots or similar circumstances....
but when turning left, and left only(right turns fine) I notice a slight slop or slight tug on the steering wheel or even mild wobble if you will.... I've checked the wheel bearing and its fine, tie rods and steering arms all tight, but the cv half axle is able to move in and outward just slightly, not sloppy though.... so i'm wondering if this sounds like the culprit, or is there something else i'm missing??? what do you guys think?
as i said before at higher speeds it's not noticeable...but slow tighter left turns and ya can't miss it.....
thanks
thanks
