Left Rear Vibration/Suspension Questions
postalc38
Well, I think either my LR strut is going out or the mounts are shot. Car seems to drive smooth at higher speeds, but when going around 15mph it sounds like something in the LR is shaking like a mofo. Also realized today when I was cleaning out the trunk there's a creaking noise when I push down on that side. I crawled under it the other day and checked out the trailing arms and sway bar links, everything looked good there.
Thanks to my crappy 6 on 1 off schedule (where it seems I get screwed by weather to work on the GP) I think i'm just gonna have to end up paying out the ass for some quick-struts and having a shop put them on while I work one day.
So - Does anyone have any other suggestions to look at other then the trailing arms and sway bar links (which are fine), or do I sound as sure as I am that it's the struts?
Also - If I add a front strut bar after I replace the struts, is there two different strut bars for the 3800 and the 3100/3400? Someone mentioned it at work the other day there may be a slight difference?
