LED interior
klj5022
KSteelwheelzJ
Okay so i have figured out that i want to convert all my interior lights to blue and white LED's(Back seat map lights, Dome lights in front, and floor lights in front). I know what bulbs to get for the front floor and back maplights, but there is a size choice option for the dome lights up front 36mm, 39mm, 42mm and 44mm does anybody know the length i should choose. The website i am using is SUPER BRIGHT LEDS - LED Lights & Accessories, and yes i know they give a Sylvania bulb reference but that doesnt help when it comes to length of the festoon bulb:confused:
the ones from superbright u can eitehr do the 36 or 39. they both fit. I think i did the 39 though from superbrightleds.
Hey Warbeaver which lights did you use all around on the interior i checked your cardomain page and i like your setup?
I went with the dioded dynamics, superbright should make it as easy as they did, i almost bout one of the kits but i only wanted the interior lights that come on when you open the door to be blue, i bought one white dome light so i would be able to read stuff if need be at night
Good luck with the rear seat overhead lights. I struggled for an hour trying to get that sonofa***** suare plastic insert back in for reassembly. Anyone have a tip for that? I do the other side today.
How long did delivery take?:th_sign-thanks:
4 days to Upstate NY. I seem to have a problem with the trunk LED. NOT a problem with Diode Dynamics. On occasion the LED is dim and flickers. Any LED I put in it does this. They all work fine in the front footwell area. If I open the front door (and the footwell LEDs are on,) the trunk light works fine. But trunk open only it is hit or miss. Anyone got an idea? Low voltage problem?
Got them all in, i shoulda went with all blue because the white isnt even as bright as the blue dome light and i can see plenty clear with the blue. Oh well i will have to wait till i need more lights because shipping and handling for one bulb isnt worth it
