Monty... here's the "easy" way. I say that because if you search "easy" and my Sn, you get all the how to's that I've done.
http://www.grandprixforums.net/how-remove-transmission-35485.html
I support motor from above
Zip off tires (put under car. In case jackstands fall..these will give you a fighting chance
Drain trans fluid
Remove the 4 15mm nuts holding the engine and trans mounts to the subframe
Remove the two 18mm bolts holding the rack to the subframe. Then wiggle to ensure it's free.
Remove the 10mm bolt holding the ps rack line to the subframe
Remove both axle nuts and tap axle to free it of the wheel bearing.
Remove the balljoint cotter pins and 18mm nut from each side
Remove the 10mm bolt holding the brake line to the wheel well.
Using a large prybar. Come in paralell to the body of the car, over the control arm, under the body by the driver door. Push down on that while you smack the side of the balljoint with a large hammer. This pops the joint free w/o hurting the boot.
Now your subframe is 4 18mm bolts away from being on the floor.
If you don't have two jacks like I do.. you can leave one balljoint nut barely on to hold up one side for you.
Then the subframe is down... the axles are ready to come out of the transmission and you don't fight any steering rack, alignment etc issues. Clock spring can not be an issue, bleeding the system etc can't be an issue. Tis all good.
