Well since negative LTFT's mean you're running rich and the PCM is pulling fuel I would think that you would lean it out, but my only concern is that the O2 readings were indicating that I was running lean. I know narrowbands aren't worth a ****, but if my car is really running lean and I lean it out more that would not be good.
My thoughts exactly
From what i have gathered (not sure if i am right though):
Narrowbands are designed to read 14.7 AFR, any different and it can not read correctly. At WOT the AFR is say 12.4 (Stock) and lower depending on the PE Vs Time table so the narrowband is useless.
the negative LTFT at WOT the PCM based on the rest of the LTFT gathered under regular driving based off the 02 sensor reading 14.7 AFR.
we are running rich under normal driving so the computer assumes that we are going to be rich at WOT
To correct this we have to do MAF and/or VE tunes until the lifts become closer +3 to -3 under normal driving and when the PCM sees that the fueling is on under normal driving it will assume that fueling will be on for WOT and lock the LTFT in at zero.
Since I am so close to stock I think I will mess with the Maf and leave the VE alone until I get more modifications.
__________end what I gathered
new questions
If i get the ltft in line under normal driving and they lock into zero at WOT does it matter what the AFR is set at?
Can I set it a little lower say 12:1 in an attempt to kill some knock?
I know eventually that the commanded AFR table will eventually add timing for me so it cannot be set to low. Is there a safe AFR to set it at for a relatively stock car?
Please don't be afraid to tell me I am wrong this stuff is pretty new to me
