So I pulled up to work today and as I park it started billowing smoke from the engine bay, out the sides where fender meets and into the cabin. I checked the temp gauge and it was perfect, I immediately turn it off and open the hood. After the smoke clears it’s obvious it’s from the rear of the engine, I look under and in the 30 seconds it’s been off I’ve already left a good size puddle of what looks like oil from here. So I’m assuming something is leaking onto the manifold or downpipe area. I checked on it couple hours later and the puddle is much bigger.
I’m getting it towed home in a couple hours when I’m off work. Question is what in the back side could be leaking onto the exhaust area? I was thinking an obvious place to look first would be at the valve gasket, as it’s right above it. Anywhere else to look at? Thanks for the help
