Pure2sin
I keep hearing a leaking hissing noise from someplace around where the master cylinder and EBCM are. I have not noticed any issues with braking but if it has been steadily getting worse I possible could not have noticed.
Is it possible to have an air leak someplace on the master cylinder or is it more likely something to do with the brake booster? Is there supposed to be a specific gasket or seal between the two?
Also..Does anything think I leak in that area could cause the car to have a vacuum leak and run lean? I would think if it were the booster it could cause the lean condition.
