Leaking Coolant
gordster1122
I have an 04 gp and Today at work I noticed a puddle of coolant under my car I drive an hour to work and I just had enough to make it home I know my lim gasket need to be replaced I just wanted to make sure its the lim gaskets causing major loss of coolant or be a rad hose
Check the coolant elbows under the alternator and near the lim. They are plastic and crack over time and cause this.
thats elbows, or the water pump. car off, grab the w/p pulley with 2 hands, push it on one side, pull the other then back and fourth, if you feel play the wp is bad. under it will be wet too.
