Laugh with me at my failing BCM + questions
acidcrashdburnd
Issues
-TCS wont turn off sometimes
-everything in the car but the tach will turn off and I have to shut down and restart the car
-the car wont recognize that you have released the parking brake until you put it in drive and some times not even then.
-It thinks doors are closed when they are open
-It thinks doors are open when closed
-the blower motor will shut off for 3-5 seconds and turn back on.
-the factory car alarm randomly went off once @ 3am
Questions
-Where is the BCM
-Can I use a junkyard BCM
-Whats something like that going to cost
-Could this just be a bad ground
IIRC the BCM is behind the driver side of the dash. Pop the side panel off and you should be able to see it.
My factory alarm goes off anywhere from once a week to three times a day. It's pretty random but very annoying.. Especially at work.
pretty sure you can just get one from the jy, they need to be programmed. Im in the same boat i think, just messes with my idiot
