L67 swap
you don't need to change the transmission, but you can, and might as well put an XP cam with ported heads when you do a top swap.
Thread title says L67 swap but you ask about a top swap?
So what do you really want to know? A trans swap and cam swap isnt needed for either. Transmissions arent any stronger between the two, just different gear ratio and a different camshaft is just an option the owner can take if they want more power.
While it's barely worth mentioning. The diff is a smidge stronger and the output shaft is slightly different too.
