izup69
Destroys cars
Ok so the 97 gtp has pod gauges ne way it has what I believe is a kr sensor its cheap and it goes from green to yellow to red. Without taking it out what would that run off. The pcm or the knock sensor.
It has a narrow-band air/fuel. The car seems to run lean when it is first started up but after it warms up it seems to trim out and run about perfect. But after I put the boost to it it seems to run to the lean side for a min to two. Kinda funny.
I don't have the 200+ for a wide-band as ive just replaced the whole rack. I think the car was tuned at some point b/c it shifts out of second gear at like 5k rpm at wot. Would someone doing a ****ty tune on it have anything to do with all the stuff that seems messed up. Im pritty sure it would but is there anyway to tell if it has ben tuned w/o having to pay someone like 300 bucks to get into it or is there a way to reset the tune and see if that helps.
The KR gauge runs into the red sometimes and it scares the hell out of me that it is going to blow up. I have only filled it up once with 92 octane. I don't know if the KR gauge is correct of if its a pile of crap they put in there for looks.
The oil press says its running like 75psi at idle I'm guessing that's way too much and when i get on it it runs about 100psi. What is the correct oil press. How would I fix the massive oil psi. Would I have to drop the pan and check for a high vol oil pump or could it be too heavy weight oil making it run extreamly high like that.
All I know that it has had done to it is a dp catback and drilled and slotted rotors and k&n cone. My wife has the car atm and I don't have a tape measure to check the pulley size by measuring it. I got some pics I will post of pulley. There is no markings on the pulley itself.
