knocking in reverse?
buschegt
Ok so along with my misfire on cylinder 5. I've noticed when I put it in reverse it sounds like a rubbing or something coming from the front of the engine maybe from the drivers side. Its not low on oil. I pulled the #5 plug 3 weeks ago after changing it a month before that and that was like burnt up. I know its running lean but west would cause that noise?
check out your half shafts...... might have a torn boot and the cv joint is bad and only knocking in reverse at the moment
I had a similar sound while in reverse and occasionally when coming to a stop....ended up both diagonal braces needed tightening....
