OK so i pulled both knock sensors to replace them on the GTP since the rear one was damaged and figured it was time to R&R the sensors...new cam and crank sensors on the way in since i decided to order everything and save myself some money along with the knock sensors and just kinda prepping everything since i have been stuck in the hospital...anyway when i pulled the knock sensors i had a ton of water pour out and cannot find if that is normal or not...just need to ease my mind here and trying to see if its something i should worry about or not...
i had to get a new knock harness for the rear because that was the wiring that was hardwired into the fuse box that i removed and being the sensor was broken i figure with it not bypassed anymore could be part of my rough running issue before the car died...
