Knock Retard
Depends on what kinda setup you're running. Old mounts, parts hitting against eachother can cause false KR. Usually headers is a good way to kill some KR. Or an IC. Pulley up and stay out of boost.
you could try setting a trap and releasing it back into the wild. Maybe try spraying some knock repellant around your rocker panels.
I've always been told you can take a solid blunt object, such as a Baseball Bat, or Tire Iron, etc... and hit the retard on the back of the head. Upon knocking the retard unconscious you can simply drag them into a cage and keep them away from the motor as to not cause more problems.
I myself have not tried this, as I keep my retard under control and chained in place, but whatever works for you.
Try some research and see what others have done to solve their retarded problems.
