Negative.
Important note - you MUST program all of your keyless remotes when you do this - NOT JUST THE NEW ONE. You are in essence - changing the channel/remote address of the vehicle and remote, and your old remotes will not work.
1) Get in car and close all doors.
2) In the fuse panel - remove the "MALL PGM" fuse - do not lose this!
3) Insert key and turn ignition to ACC position - you should hear the interior chime once
4) Turn key to "off" and quickly back to ACC.
5) Open and close the driver's door. You should hear 1 chime - this will indicate that the system has entered diagnostic mode.
6) Press and hold both the
lock and unlock buttons on the transmitter (key fob) - for approximately 15 seconds. You should hear a chime after 7 seconds,
DO NOT RELEASE THE BUTTONS - continue to hold for a second chime.
7) Repeat step 6 for each transmitter. (maximum of 4 can be programmed for each vehicle)
8) If you're finished programming, turn ignition off.
9) Replace “MALL PGM” fuse.
10) Open Door(s).
11) Test transmitters.
-Swash
