Keyless Entry Intermittent / Air Bag Telltale Problem
Vequixr
I have a 2008 Grand Prix GXP and the keyless entry is intermittent. The signal from the FOB is strong so that isn't the problem. Sometime it seems to work only after you unlock the car with the interior unlock switch. Then it will work fine - sometimes. Maybe completely unrelated, but I also have a intermittent airbag telltale that light up and usually clears after a key cycle. Does anyone know if there is a possible common connector for RKE and some airbag sensor / module that might be the culprit. It feels like a wiring issue.
