keep blowing fuse for fog lights.
RyanL
hey im just wondering has anyone ever had a problem blowing the fuse for their fog lights? i have hid fog lights 4300k, i noticed it today and found the fuse was blown, again tonight when i turned on my lights the fogs didnt come on again and yep blown the fuse a second time today. the fuse is a 10a do you think there is any danger to put a 15amp fuse in there?
You shouldn't ever go above the factory rated fuse amperage, or you chance shorting out other components.
Now, do you have the Relay Harness for those HIDs? If not, get it.
Mine kept popping the fuse, got the relay harness (like $10 or so) and solved it.
no i dont have the relay harness but ive had this kit installed for about 5 months now and its only happening now! so il try getting a relay harness but where can i get one and where do i install it? never heard of it.
From wherever you got your HIDs from.
The other option, is to trace the wiring, and see if there are any frays.
Install is plug and play.
