Gm Man
I moved my performance shift button to a red led rocker switch next to the heated seat button I wired the + to the 12 volt connector and the - to the ground connector on the switch I didn't connect the acc. connector for the led light the performance shift lights up and works fine on the D.I.C.. I read a forum where a guy said his "performance shift light on the D.I.C. doesn't work but the performance shift light on the I.P. works" now my I.P. light doesn't so I took the I.P. cluster out seen there was no bulb so I went to the auto parts store and bought one and replaced it; now this is where it gets weird I turned the performance shift button on and the led switch lit up :th_scratchhead: and the performance shift light on the I.P. or D.I.C. didn't light up. Again :th_scratchhead: Can someone help me understand this?
