Just installed a alpine cd player and now my keyless entry dosen't work. HELP!!!!
jrpassow
Also with the cd player I have to turn it on and off everytime how would you get around this. Also the keyless entrey problem. Any Ideas on how I can slove this problem. Also I have a 2007 Grand Prix.
Moved to the correct section.
I would agree with Yulaw on this one, i would check your fuse panel diagram and seek out the remote control fuse, there should be one named something to that affect. And if you cant find it? I would get a fuse tester from Autozone or ORielly's and check each fuse near the glove box.
Did you use an aftermarket wiring kit to hook up your Stereo? I know the 04+ GPs are very sensitive to changing out the stereos cause a lot of the controls go through the factory head unit.
Good Luck
If you have to turn it on and off every time you might of hooked the constant 12v(Yellow I believe) from the deck up to a switched 12v wire on the car. Take a DMM and see if you have 12v to the wire hooked to the yellow wire coming out of the deck with the car off.
