Just changed lim, reduced power on display center
Prd2010
Just replaced lim on my 04 comp g. I found a broken vacuum plug, not sure where it came from. I think it may be the t under the supercharger, it's old, but I can take the line that runs out of it and it still has vacuum. I'm thinking it may be losing some vacuum, but not enough to make it so the car doesn't run. It will start for a few minutes, throttle doesn't work, then I get a reduced engine power in my display and car shuts off. I'm wondering if maybe the vacuum plug I found maybe needs to be hooked up somewhere but the vac line diagrams don't really show where any plugs should go. I am replacing the vacuum t real soon but just think it could be more than that. Any ideas? Car ran great prior to intake gasket change.
Clear the check engine code, it's got to have one if it's going into reduce power mode.
I'd even unplug the throttle body and make no pins are bent or damaged and plug it back in. Then fix the vacuum line and see if it runs better.
Post pictures of the plug or line you are talking about, we may know it goes.
I'm just inpatient. About 15 minutes later car was running fine. Went to AutoZone and got that vacuum line right and now it's all good. Just couldn't miss work tomorrow lol. Now that that is done onto exhaust mods lol. Thanks for the input though.
