Trump
This is getting to be a pain. Last December my car, " 2004 Pontiac Grand Prix GTP " Started having a problem starting once it sat for about a half hour or less.
1) condition one was when I tried to start the car after it sat for about 15 min, I tried to start the car and it seemed like it wanted to keep turning over even after I let off the key.
2) A couple times I tried to start the car after it sat a while and kept trying to start the car and it surged like it was out of time or the cam sensor was not getting the right data, I turned the car off and let it set for over an hour, then it started right up no problem.
3) every time the car sets for an hour or more it will start perfect 100% of the time, but when the car set's for 10-15 minuets it normally acts up.
4) I have changed the whole ignition switch, cleaned the contacts also
5) I have changed the starter
6) No CODES COME UP
7) I had the car on the Snap On scanner
r and had it fully tested to see if something would come up, NOTHING showing on the Snap On Scanner.
Any Ideas ??
6) No CODES COME UP
Any Ideas ??
