Hey guys, I have a 1997 grand prix GT. I top swapped it using a 2001 grand prix GTP top end. I have an odd issue going on. This happens ONLY at 160 degrees or hotter exactly, and it ONLY happens at an idle.
When I hit a red light at 160 degrees or hotter, my volts and RPM's drop at the same time together, then bounce back up and it idles a bit higher than it should.
I have replaced all of my sensors, and alternator, and battery. The PCM has been flashed at ZZP and it has been dyno tuned.
occasionally I'll be driving down the street and the engine will shut off on me, a check engine light comes on and it scans MAF sensor, I replaced the sensor twice now in case I bought a defective one.
Could this be a short in the wiring to the MAF? any help is appreciated! thanks!
