Is it possible to get a factory auto start on an 04 GTP?
Stackz73
I want to get the factory auto start like the 05+ gtp's have on my 04 but idk what I would need for it or if it's even possible. Any ideas guys?
nobody has done it successfully. you need at the very least the Keyless Remote, BCM and the Extended range antenna that requires a different rear glass window
Its too hard with the '04 at least to do it from the factory. I also found a lot of issues with the factory alarm too with aftermarket options. I wanted autostart for the winter. I got a block heater instead as that's the only reason I wanted the autostart. Try a block heater if that's why you want the autostart if you are close to an outlet in the winter at all.
