Hello everyone. My name is Victor and I'm a new member to the board. I have been searching the threads for a while now, but it's time I just ask for help.
I just bought my 97 gtp (120,000) about a month ago. When I bought the car, the guy told me that he had replaced the trans with a built trans with 10,000 from a guy who blew his engine up racing and didn't need the transmission anymore. I don't know how accurate his info is regarding the built and mileage.
When I bought it the trans did not shift bad, except for when i would rev to 3000-4000 rpm it would feel like it was in neutral. If I held the rpms steady it would shift. The trans also make a grinding noise upon start up but stopped after warming up.
I cleaned the maf and havn't had a code since. The trans started giving me problems and the car would stall and refuse to start after a while. I changed the crankshaft position sensor and stopped the stalling problem. I just changed the trans fluid and filter, but to no avail. I also cleaned the grounds.
The transmission has gradually gotten worse. At a cold start I get the same grinding that disappears. My car also is stuck in first for a while. It sounds like I also have whine from the transmission. Once it shifts it will continue through the gears but 1-2 and 2-3 will be harsh. 2-3 is worse. Now everytime I leave a light it has a hard time entering second. In D the revs will go up and then it will start slipping and if I rev it harder or take my foot off the gas the car will respond like N. I have to put it into 3 and rev till till the gear catches. Eventually I can get it to shift to second, then I can put the car back in D and drive normally. WOT and neer revline help it to shift to second as well. After driving for a while things start to work better, but usually not perfect.
Now the weird part. Sometimes (rarely) it randomly shifts perfectly. It will go right into second too. Unhooking the battery lead can also sometimes cause good shifting.
When I was filling the transmission with fluid I could hear air escaping somewhere else. I don't know if that is normal.
I can't tell you how much I would appreciate some help. Your forum has already been a great source of knowledge.
