Ok I found a few threads about this but I just want a second opinion about this. This has been happening for a while and its more of an issue now as it happens about everyday instead of one or twice a month. I did have a worn ignition switch a few months ago but I put a bypass relay in and now my DIC, fan speeds, and defroster now work. But now I'm thinking its a problem....
About everyday now when I go to start the car... it just clicks. I hear the relay in the dash click but the starter doesn't even try to turn. Now if I keep turning the key to try and start it sometimes it only takes a 2-5 times if I'm lucky but sometimes it takes about 50-100 turns to start and when it does there isn't even hesitation. So..... do you think its the ignition switch? or the trigger wire? Or maybe the solenoid itself?
