Intercooler pump wiring
triebenbach07
I recently picked up a S2 IC setup. Where to I wire my pump to for a power source so that the pump comes on with the engine? As always, pictures are very helpful if words don't get the point across. Thanks guys!
Ugh.. while it works...
I'd suggest using the fuel pump or injector circuit for power to work the relay.
Ground much closer to the pump.
Power from battery or top post of relay center
Ground for relay right near the relay
And ... ensure the relay is waterproofed if it's under the hood.
