intake help (i know its redundent but i need some advice)
The M90 doesnt compress. It just shovels the air in. To the OP, pick whatever air intake suits your fancy. You will not notice a difference between any one you choose, no matter how expensive it is. It's really just eye candy. You really want to notice a difference, intercool. That way you are cooling the air after its gone through all the hot parts.
Well what I meant is that it puts the air under pressure and shoves more in there than it would be able to suck in with a natural vacuum, raising the air pressure inside the manifold, right?... and that process in itself generates heat. Along with it spinning very fast
Putting the air under pressure is compressing. The M90 is a root style supercharger. Basically, the M90 is a fan in a closed circuit, drawing more air in than the motor can by itself. The heat comes from the friction of the impellers spinning inside of an aluminum case. A screw style blower will compress.
