Intake & exhaust wrap?
maybe_memories
This might be a stupid question but: If running a cone filter with a metal intake tube, would there be any benefit in wrapping the intake tube with exhaust wrap? I was kinda thinking it might help keep the tube cool and keep the air cooler going into the tb.
Im not sure the wrap would help, I believe it is more intended to keep heat in. However, you can get a product called Reflectix at hardware stores that is designed to keep heat out and may work better for you.
I posted this on another thread, may be helpfull to you.
The intake air temperature significantly influences the horsepower output of an engine. For example, if an engine's intake temperature was dropped from 110°F to 75°F, then the change is horsepower is approximately +7% ( -1% @ 75°F minus -8% @ 110°F). If the engine normally produces 200 horsepower, then this 7% increase in power translates to about a 14 horsepower increase. Achieving the lowest possible intake temperatures is therefore very advantageous.
Anything you do to reduce temps is good. I agree with Scotty, the reflectix material may be better. Wizaired uses it inside their boxes. Also is your cone inside the fenderwell? If so do you have a blockoff plate so the tube fits snuggly going into your fender? You want to keep those high engine temps from being sucked into your intake for the most benefits.
