intake conversion questions
No Mike.. you won't benefit from that, because it gives you an intake manifold that you can't use, an upper intake manifold that you already have and an HV3 insert that you might benefit from at the higher rpm.
but could I use this? would it allow me to keep an N/A motor and use the billet fuel rails and n* tb? its more because I want the billet rails than anything.
No, the kit retains the L67 cylinder head. You do not have L67 heads. Therefore your injector ports are in the LIM. the L67 ports are in the head.
